โApr-17-2017 01:01 AM
โApr-17-2017 07:37 PM
โApr-17-2017 12:33 PM
independent_TJ wrote:
Thank you both for clarifying:
1) The indicator light does NOT indicate that "ELEC" is operating...and... When on 'Electric' there is NO Indication ---you just have to wait 8-12 hrs upon start up to have cooling (you can check electric element ---hot)
2) There is no control board on the RM2601. Correct...so no electronics needing DC
When on shore power AC, is it required to have a 12v battery on the tongue? (I thought the AC/DC converter would provide the 12v to this appliance? All DC fuses in bedroom fuse panel are good, and so far, all other DC electronics are working without problems). 12V DC SHOULD be supplied by converter via DC Fuse Panel when connected to 120V AC power source.
No 120V AC power source then trailer Battery supplies the 12V DC via DC Fuse panel
Converter also CHARGES battery and MAY need battery connected/fuse to use as a 'load'---depends on WHICH converter you have
What is powered by the fused line from the 12v battery? Fuse DC to fridge is for interior light and reignighter DC power IF you are referring to in-line fuse on battery POS cable on trailer tongue THAT is so battery can supply DC to trailer if no 120V AC and so Converter can charge battery when on 120V AC)
Thanks in advance!! I am always rushing to do as much as I can when I have time to go work on the cleaning, restoration, and renovation (bedroom needs a new floor)....so that leaves little time for manually tracing wires. ๐
โApr-17-2017 11:19 AM
โApr-17-2017 10:35 AM
โApr-17-2017 02:48 AM
