kohldad
Mar 23, 2020Explorer III
Since you have a good truck, I wouldn't worry about the weight difference. Yes the hardside will be a bit more unstable, but it shouldn't be bad at all. With the hardside, you may need to do a few minor suspension upgrades like heavier sway bar, stable loads etc.
I have a Lance 815 which is a bit lighter and not only do rough forest roads but also easy off-road trails.
I would be more concerned with how you plan on using it. If you travel all day and only stop at night, the pop-up may be a better option. But if you use the rig several times a day, then you will probably more satisfied with the hardside.
44,026 PostsLatest Activity: Mar 01, 2025
