jimh406's avatar
jimh406
Feb 09, 2014
DRW vs New DRW for TC Hauling
I've been doing some research since I'm pretty much only driving my truck any more when the TC is on it. It's getting some age on it, so I'm considering getting a different truck that isn't a compromise for hauling. Obviously, that means I'm looking at DRWs.
Next up, DRW vs New DRW. Some makes including RAM are rated significantly higher than models even a few years old. The question is if you've had both, did you experience much of a difference hauling your TC between your newer higher rated DRW from '06 on compared to the very newest DRW models that are rated to haul almost 2K more?
If you did, what did you have, and what did you switch from? I found some interesting things out. Ford went away from 19.5s on F450s and just are moving back to them. RAM now actually has a nice interior and have absolutely way better initial prices, but maybe that's a function of advertisements.
In case you are wondering, I'm leaning RAM. I must have been asleep when the took over the market segment.
