Aug-20-2012 09:18 PM
Jul-15-2013 03:43 PM
jack0351 wrote:
LOTS of things to consider- payloads and weight ratings, etc. If you truely dont want to outgrow the truck, look at the largest FW you would want now, and then buy a TV to match that. It may be overkill until you get that FW, but you will not have to worry about being too small when you buy the FW.
I ordered my Voltage, and then realized the truck I had wasn't going to cut it, because I didnt do enough homework, and fell into the "a 1 ton can tow anything" trap. When I finally sat down and worked the numbers, the (older-2000 MY) 1 ton wasnt rated high enough to tow my Voltage empty, and had to scramble to find a more suitable TV. That was how I ended up with my F450.
If the TV will also be a daily driver, that will factor in a lot as well. You need to WANT to drive your TV as a daily driver, and if you're not comfortable, it sort of defeats the purpose!
Aug-27-2012 02:27 PM
4x4ord wrote:smcrea wrote:
Hi All,
Thanks for all the discussions on this SRW vs DRW quesion:
I was trying to sum it all up and came up with this.. am I close?
- $345 difference in price from a SRW
- People say that the DRW sits on the road like it was on rails when towing and is much more ‘stable’
- It is however wider by about 12”. People say that if the mirrors fit then your hips fit as well but you have to be careful when parking.
- The DRW carries more load than a single rear wheel and so opens the 5th door to just about anything we can see.
Would I be able to tow most except the VERY largest 5th wheels with a SRW 3500?
My problem is that one we arrive on site and setup the RV then the tow vehicle becomes the family car, so we cant have something that is unusable as a family car for sightseeing, shopping etc
-If you are pricing a Ford the short box SRW with 20's is actually a little more than the dually but if you go with 18 inch wheels on the SRW short box you can save about $1260 over the dually long box.
-Stability is a non issue with the new F350 SRW with 20 inch wheels regardless of how stable the dually is. My guess is that the new GM 3500 SRW is more similar to the Ford but even though our 2010 Duramax SRW is quite impressive as a tow vehicle it feels significantly less substantial than the 2011 Ford when towing.
- The payload advantage of the dually becomes a big deal if you are planning on towing a 5'ver much over about 15,000 lbs.
-Because Ford requires that you go to a 3.73 axle in the dually vs the SRW there is a significant fuel savings with the SRW. The 20" wheel option requires that you go to a 3.55 ratio axle which will cost a little on fuel over the 3.31 axle. The GMC uses the same axle (3.73) for all their Duramax configurations and the difference in fuel economy is less significant whether you go duals or not.
Aug-27-2012 11:01 AM
Aug-27-2012 11:00 AM
smcrea wrote:Cummins12V98 wrote:Glenn West wrote:
My Mobile Suites has a pin weight of 4400#. That is rather much for 2 E rated tires.
My 36 MS has 4,500# pin wt. 4,400# are on the rear axle. My rear axle weight is 8,280# a nice load on 4 tires but two????? I see one guy here with the same rv as mine that his name starts with a R and ends with a U that thinks his red GM single rear wheel is perfectly safe.
Big rv, get a Dually and keep your family safe and others!
Thanks for the reply..
I'm struggling here.. so to help me I went to Holman Motors website and was looking at 5th wheels and sorted by weight with heaviest first.
http://www.holmanrv.com/types/fifth-wheels.aspx?s=true&page=1
To help a complete dummy like me get a perspective can someone tell me which 5'ers I would NOT be able to pull with a 3500 SRW... again sorting from the heaviest down?
Thanks for the help!
Aug-27-2012 10:29 AM
Aug-27-2012 10:03 AM
Aug-27-2012 09:38 AM
Aug-27-2012 09:04 AM
Aug-27-2012 06:48 AM
Aug-27-2012 06:40 AM
Aug-27-2012 05:07 AM
smcrea wrote:
Hi All,
Aug-27-2012 12:34 AM
gmc6000 wrote:
As a former dually owner, I can say unless you are pulling real heavy, over 16,000 lbs and need the extra payload capacity, go single wheel. Duallys are terrible in the winter, and the ride is rough when empty. As I said, I have had both, and would never go back to a dually unless absolutly needed due to weight issues.
Aug-26-2012 10:44 PM
Aug-26-2012 09:53 PM
