Sheriffdoug
May 18, 2013Explorer
Dually Outside Measurement to Jacks Each Side
Hello,
Can someone tell me what is the gap between the Jack legs and your Ford/Chev/Ram Dually Fenders when loaded?
I assume even with swing out brackets for Jacks the gap between fenders and Jacks will be less.
I can usually reverse in correctly in 10-15 minutes for loading camper, regularly getting out to check all gaps are even and load is
as straight as possible.
My gut feeling is with less tolerance or gap, that is to reverse in,
it will probably be easier.
Not yet knowing the shape of the basement, as some manufacturers have
truncations/projections for plumbing etc.
I will be ordering new Eagle Cap 1160, sight unseen, as with my two previous TC's.
Please tell me what your TC Jack to outside Fender/Guard measurement is.
And yes, comfort is, all of you have done it, so will I.
Just being prepared.
Thank You.
Thank You.
