Cummins12V98 wrote:
Bionic Man wrote:
My truck in sig will be two in September. I have about 23,000 miles on it, almost all of which are towing. I would not want to use it as a DD if I had to drive in the city.
My Cayman makes a much better DD.
I have basically the same truck and I drive into downtown Palm Springs and parallel park with no problem.
Yep, but yours is the magic truck. From your posts, your truck runs faster, gets better MPG, lower trans temps, etc, etc, than mine.
If you are claiming that it's as easy to parallel park on a busy street a DRW as a SRW, or that it is as easy to park in a parking garage, I will have to run your posts more through a filter than I have in the past.
