Roadlover's avatar
Roadlover
Duramax Won't Start
I don't run my truck as much as I use to so I can save it more for when we want to travel. But when I have used it this winter, it starts up just fine and in the two years I've owned it, I have never felt a need to plug in the engine coolant heater. So, this afternoon, after about a week of sitting exposed to temperatures ranging from 20 to about 0 and not being run, I needed to use my truck to pick up some material from Lowes. I turned to ignition to the start position waiting for the glow plug light to go off and when it turned off, I proceeded to turn the engine over. As expected, the engine jumped on and ran for about 5-10 seconds then quit. I tried to start it again but it didn't like even want to spark. I have plenty of cranking power but nothing happened. I was hoping it maybe needed to be plugged in but after about 5 hours plugged in, it had plenty of cranking power but no indication it was going to even try to start. This time I also tried to turn the ignition to the start position but the glow plug light now only goes on for a very quick split second then goes off. Any ideas? Thank you
