Electric Jacks
burningman
I’ve always read that Happijacs are junk.
One thing I wasn’t happy about on my new Northern Lite was its got ‘em.
It’s onjy been used a few times, it’s a 2017, and one has already failed.
A lot of people cursed with these things actually carry a spare jack motor head as part of their normal gear.
Rather than replace one after another and deal with them failing at inopportune times, I think I’ll cut my losses and replace them all with something else.
Is there a consensus on the reliability of Atwood vs Reico Titan? Or any other particular advantage to one over the other?
I’ll eventually put my Stable-Lift on it but it’s still being used on another camper.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
19 REPLIES 19
K_Mac
7 yrs. so far and no issues with my HJ's,I put a few drops of oil in top and spray legs with some silicone every trip. I do not use a lot, just enough to do the job. When I would use too much oil I could see the excess all over the legs, as I said a few drops.
hedge
I had one motor go bad. Since then I've covered the motors with 3-gang electrical box gaskets year round. They probably don't look that great and maybe it's placebo, not sure... but haven't had a problem since.
2017 F350 Platinum DRW
2013 Adventurer 89RB
Geewizard
TxGearhead wrote:
For preventive maintenance on my Happijacks I found 1/2 gallon plastic buckets to cover the motors. Hopefully keep water intrusion to a minimum. Wind will blow them off. I used twist ties to secure the bucket bail to the motor wires.
I use gallon-size plastic bags.
Good to see another Go-Devil Surface Drive owner on here.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
Glacier_D
My experience with HappiJac is that they are pure garbage. Granted I used my camper in the winter where the roads are salted, owned my camper 10 years and on my 3rd set of jacks and motors, 2nd motherboard and second remote. I have the newer 4800s (zinc plated) and they are just as rusted as my old 4500s and 4600s.
Don't drink their koolaide, their jacks do not hold up!
2011 Dodge Ram 3500 4X4 Crew Cab/LB, Rancho RS9000XL, Stable Loads, Superhitch and FastGuns. 2009 Eagle Cap 1050, Hickory interior with on-board generator, A/C and Honda EU2000
TxGearhead
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
joerg68
Nomad III
Nomad III
The old HJ motors were a bit sensitive to water intrusion. The new design - which looks a bit like the old Atwood - may avoid that issue, as the motors now sit at the top of the motor head.
FWIW, I had 5 HJ motors on my Outfitter Apex. One for the roof, four for the jacks. One of the jack motors was seized and thoroughly corroded after the second winter and had to be replaced. The jacks themselves and the other motors were fine.
Replacing a HJ motor is a simple DIY job, but not cheap.
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
jimh406
Not sure who sold the most, but from what I’ve heard here, it seemed Atwood had better customer service. I think that makes people more tolerant of failures.
My 13 year old jacks have had two issues. One remote controller died at about the 2-3 year mark. The switch to turn them on is intermittent. A shot of WD40 seems to get it working again.
otrfun
sbryan@vtbryans.com wrote:
I lost 1 HJ motor early on and otherwise they have been fine. I think it's a **** shoot on what is best. Remember that happy people don't post but people with problems do so the comments are always skewed. I suspect there are lots of happy HJ people who don't say anything (me included). One motor failure, covered under warranty, was an easy replacement and has worked fine since. JMHO
Is it possible HJ outsells the other brands? If so, it would stand to reason there might be more complaints.
Without knowing how the number of HJ problems/complaints compare proportionally with other brands makes it kinda hard to know whether HJ is actually more problematic or not.
sbryan
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
Geewizard
I've had exactly one motor failure on my Happijacs since 2004. That's the only issue I've had.
Proper maintenance is the key with ANYTHING mechanical, IMHO.
joerg68
Nomad III
Nomad III
There are no more new Atwood jacks. They were bought out by HJ.
Your options are HJ or RT.
It remains to be seen if the new HJ motors are more robust/reliable.
Grit_dog
Navigator
Navigator
Seems like a waste of money.
Kayteg1
I have 2 TC with Atwood jacks and both systems are 18 yo.
Can't say how PO used them, but they had to be abused since all front brackets were bent when I got them.
I use the jacks tens of times when I am on my vacations and don't know (knock on the wood) what is jack problem. Even when I don't unload, I still lift the camper on jacks for stability.
My Fleetwood camper was scaled at 5500lb at some time.
zcookiemonstar
I have Reico Titans and one of mine sometimes does not want to work. A few manual cranks with a ratchet usually gets it to move but sometimes I have to play with it for a while. Camper it about ten years old and had this problem for a few years now. I don't have any experience with the other brands to compare.
