โApr-17-2021 07:54 PM
โApr-18-2021 05:46 PM
โApr-18-2021 05:29 PM
Delano1981 wrote:
Thanks everyone for the replies. I think I'll follow the advice to hard wire it to the trailer battery. That will be a simple solution.
Thanks
โApr-18-2021 12:47 PM
โApr-18-2021 07:47 AM
Diamond c wrote:
If my camper battery is dead nothing on the camper work but the lights when I plug the camper to the truck. I need to put a fuse in the fuse block of the truck,although I donโt know where. You might try charging your camper battery and see if that works.
โApr-18-2021 06:58 AM
โApr-18-2021 06:40 AM
โApr-18-2021 05:24 AM
WNYBob wrote:
Jerry, the OP said he just added positive power to the jack pin! He didn't check the truck output.
โApr-18-2021 04:28 AM
โApr-18-2021 04:20 AM
โApr-18-2021 03:48 AM
WNYBob wrote:
Check your truck manual, I needed to add a fuse in the fuse box, it may be blown or not there.
โApr-18-2021 03:44 AM
ScottG wrote:
Sounds like you figured it out - the jack is using the trailer for ground and not the ground at the trucks 7 pin conn.
Personally, I would cut the connector off and wire it to my trailers battery like most jacks are.
โApr-18-2021 03:43 AM
โApr-17-2021 08:13 PM
