Gdetrailer
Oct 19, 2020Explorer III
MrDesjardins wrote:
Thank you all
The suv can haul 5000 pounds and the trailer I have my eyes on is 3500 pounds (https://www.rvusa.com/rv-guide/2013-jayco-jay-feather-ultra-lite-travel-trailer-floorplan-x17z-tr13211)
The hitch on my suv is there: https://photos.app.goo.gl/H5PcZviPvkUKaT7e8
Make sure you have enough available cargo capacity of the tow vehicle.
Generally you will run very short on cargo capacity before you get to the max towing rating.
That trailer tongue weight empty is listed at 405 lbs, generally that does not include the weight of a battery (required for brake break away system on trailers exceeding 3,001 lbs) nor does the dry tongue weight include the weight of propane (some may not include the propane cylinder weight either).
Battery and propane will add nearly 100 lbs to the tongue..
I suspect your tongue weight when equipped with one battery and one 20 lb cylinder will be around 505 lbs and that is before you ever get your gear in the trailer.
This trailer is also listed with only 600 lbs of cargo capacity and battery/propane will take nearly 100 lbs from that..
If GVWR is truly 3,500 lbs your tongue could weight as much as 525 lbs..
Not sure if your vehicle is designed for WD (I didn't review the hitch pix), but if you need it, that will add more weight to the tongue. Adding WD hitch will take away cargo capacity of the tow vehicle.
Pretty much in a nutshell, to tow this trailer loaded, you WILL need at a minimum of 600 lbs of available cargo weight with your selected vehicle.
Keep in mind, any passengers, gear or other items put into the tow vehicle WILL use up your available cargo capacity of the tow vehicle, REDUCING the weight your vehicle can tow.
Please, PLEASE, check your yellow door cargo sticker to make sure you have enough cargo capacity, do not rely on those supposed max tow numbers, they are often way overstated..
44,030 PostsLatest Activity: Jan 20, 2025
