Gdetrailer
Oct 20, 2020Explorer III
Lwiddis wrote:
Family with ONLY 600 pounds of water, batteries and stuff? NOT likely, GDE.
I don't know where YOU are getting YOUR NUMBERS??
Trailer the OP linked is a 18 ft light weight hybrid trailer with a GVWR of only 3,500 lbs, advertised dry weight is 2,900 lbs. Giving them 600 lbs of cargo on the trailer.
Tanks are 28 gallon each, it isn't like they are EVER going to travel with ALL tanks completely full now are they? Would YOU? I wouldn't.
So, for grins lets say they filled their fresh water tank full, that is 246 lbs in fresh water.. Now while they are camping they DUMP both the black and grey BEFORE LEAVING THE CAMPGROUND.. PROBLEM SOLVED.
I NEVER leave a campground with grey and black tanks partially full or completely full, I DUMP THEM BEFORE LEAVING.
In reality IF they traveled with a full freshwater tank, they should have 354 lbs for food, clothing, pots, pans, silverware, dishes, bedding and perhaps a few electronics.. keeping in mind it IS a 18ft trailer and it folds in removing a lot of storage space that you would have with a full hard sided trailer, they WILL be hard pressed to put more than 354 lbs of stuff in that trailer.
And YES, folks CAN LEARN to travel light, it CAN be done.
Lliddis, I suspect that you are being rather silly, I suppose you feel they should be dragging this trailer with a 1 ton truck?
It is a 3,500 lb GVWR trailer, which at 15% TW the tongue would be 525 lbs, OPs vehicle has a towing rating of 5,000 lbs. Their vehicle door sticker gives them 1173 lbs of cargo capacity.
Now, to refresh YOUR math skills I will do this slowly..
1,173 (TV Cargo Cap from door sticker) - 525 lbs (15% TW of 3,500 lb trailer) = 648 lbs of leftover available cargo for the Tow Vehicle..
WELL within the capabilities of the Tow Vehicle manufacturers recommendations and in reality they could have 3 additional full sized 200 lb adults in the tow vehicle to boot!
IF they were looking at a trailer that had a GVWR of 5K or higher, I would not have considered that as a good idea.
Is it an "ideal" tow vehicle? I don't know, but in the end, the OPs trailer choice does happen to be well below the max specs of the vehicle.. I suspect the vehicle manufacturer knows a lot more about the vehicle they built and sold to the OP than you or I do.
And, yes, I am hypercritical when it comes to the ratings game, heck my F250 has 4,000 lbs of available cargo weight and I am only towing a 7,000 lb GVWR hard sided TT which is only 1/4 of the vehicles cargo rating at 15% tongue weight.. I suppose you think I have too light of a TV also?? :R
44,026 PostsLatest Activity: Mar 01, 2025
