Equal-i-zer Hitch question - Keystone Terrain 250TRS
Gaffer222
Signed the deal today for a factory order on 2014/2015 Keystone Terrain 250TRS. Not sure what model Year will be on the VIN.
Question is does anyone have the same TT with a Equal-i-zer Hitch. I plan on ordering the 1k/10k model and assume the standard shank will be what I need. TV is a 2007 Ford Expedition.
I can figure it out on the EQ website if anyone has the
"Coupler Height above ground with trailer parallel to ground"
2007 Ford Expedition Limited w/Tow package & 3.73 Rear end
Equal-i-zer & Prodigy
2015 Keystone Outback Terrain 250TRS
DW, DD Circa 2002, DD Circa 2005
4 REPLIES 4
opnspaces
Navigator II
Navigator II
I had the same question about the coupler height when I bought my trailer. I called the dealer and the salesman grabbed a tape measure and measured one on the lot. If they have a similar model they'll probably do the same for you.
JJensen79
You should be good with the standard shank. The receiver actually sits kind of high on the Expy so you might be at the lower holes of the shank. Once you get it home double check all of bolts on brackets mounted to the a frame. Some of mine were loose after the ride home. Also double check to make sure they mount the brackets in the right locations. Mine were installed to close to coupler.
By the way, good looking TT you got.
Goldstalker
2007 GMC Sierra 1500 Crew Cab Z71 4X4 3.73
2013 CrossRoads Sunset Trail Super Lite 250RB
2-2012 Yamaha VX Deluxe
2012 Toyota Highlander
Gaffer222
What ball size do I need?
