Garyaero
Aug 02, 2014Explorer
Exterior door problems
I have a older 24' Terry trailer and the exterior door is uneven while the frame is even. Across the top from the hinge side (where it ok) to the strike there is 3/4 in difference. And the strike side from top to bottom there is only 1/16 inch difference. The frame is perfectly square. Any idea whats causing it. Is there a way to attach pictures I could do that so you could see it
