SouthpawHD's avatar
SouthpawHD
External TV Antenna at Permanent Campsite
So I have a permanent spot that we camp and TV reception isn't the best. So I had the idea to get a standard external antenna (RCA home model) and I mounted it outside. My thought was I would run the coaxial cable from the antenna into the Cable/Satellite tv jacks on the outside of my TT and then flip the tv to run on "cable" instead of "air".
However this has not worked. Perhaps it's because cable runs on whole channels and the air channels run on subchannels like 2-1, 5-2, etc.??? I just can't figure out what to do.
Any help is appreciated. We are camping now and it's raining and we just want to relax.
  • I was able to play with the antenna briefly after the rain stopped, we were able to get a channel but we definitely need to go higher and aim it better. Looks like that will be next weekends project!
    Thanks everyone!
  • I can vouch for this type of antenna
    This one is a Channel Master CM-4221, but other companies make similar ones. If you search around, there are plans online to make your own.
    Digital TV antennas are not really different than the old analog antennas. They are smaller because they only have to tune a smaller amount of RF spectrum. Also, because they tune (mostly) higher frequencies, they are much more "line of sight" sensative which means that the further you are from the broadcast tower, the higher it needs to be mounted.
  • Thanks for all the replies. I'll assume at this moment my antenna is facing the wrong direction. If the rain ever lets up, I'll mess with that and see what happens.
  • I often use a Jack antenna on a mast, fastened to my ladder, extended about 4' above my roof. I have coax fastened to cable inlet, on outside. The Jack comes with it's own power up source, plugged in inside. This gives much better range than my omni OTA, which is only good for short range to towers.
    Yes, you need tv set to OTA, when using cable inlet, for OTA viewing.
    Jerry
  • Used to do it all the time.......
    YES antenna booster OFF....TV input stays on 'AIR'
  • Unless your TV has 2 different coax inputs labeled cable and air (doubtful), you want to tell it to run on "air," not "cable." To the TV, the difference is what frequencies it scans for, and if an antenna is connected, it's "air."
    If you have an RV antenna with an internal jack and switch on a wall plate, you probably want to make sure the switch is off (LED not lit) - that switches between using the RV antenna and the external input.
  • An antenna pulls the signal out of the air and sends whatever signal it's attuned for through the wire. Analog, digital doesn't matter, advertising a "digital" antenna is just a sales gimmick. Where I live it's about 80 miles to the stations and most people that don't have satellite use one of the 150 mile range antenna's from Amazon. They come with the amplifier and rotor for about $35 and work well out to about 100- 120 miles. There are several identical ones all with different brand names. You can mount one on a standard antenna conduit I hose clamped one on my old TT ladder when I was building my house.
  • You are using your external cable input as an input for over the air antenna signal. You would need to switch the connection from the booster to the cable output to the television. Your television should continue to be set for antenna.
    As noted above, your booster is no longer involved and the switch may not improve your reception.
  • Cable just bypasses the booster so if you don't have enough signal with the larger antenna you might want to try adding a booster between the interior connection and the TV.
