โAug-06-2018 05:03 AM
โAug-30-2018 05:44 AM
โAug-30-2018 05:35 AM
โAug-30-2018 05:32 AM
jerem0621 wrote:Maury82 wrote:parker.rowe wrote:Maury82 wrote:
That push isn't the trailer wobbling, but the truck feeling pushed a bit, but placing a bit of resistance against the pressure is all that is needed. Passing pickups, cars, box trucks and most regular big rigs can hardly be felt.
Good update and post in general. It's nice to see peoples real world stories on these trucks.
Interestingly, I've talked to my brother in law who tows with a 7.3 CC 4WD F250. So a pretty heavy truck.
When I mentioned the same push I get when passed, he said he gets it too even with his bigger heavier truck.
For me, the bigger the speed difference between me and the guy passing me, the more noticable the push. I assume it's just part of towing a camper, but I have no experience with these new huge superdiesels to say for sure.
Yep, I figured the speed difference thing out quick.
I think other big rigs feel that push also, because I noticed that when being passed, their trailer will sway a bit, and at times it seem they pull each into each other.
If I can feel some buffering from big rigs while in my car, I expected it while towing...it wasn't nerve wrecking, just noticeable.
I had a 32 ft TT and initially towed it with a 97 F150. I set the hitch up perfect and on the interstate felt some push and pull from passing vehicles. When I towed the trailer with my F350 LB CC Dually I still felt the push pull.
I donโt believe anyone who โcanโt feel the trailer back thereโ if you canโt feel it then there is a huge problem. Towing a trailer should be comfortable but you should still know that you are towing.
Thanks!
Jeremiah
โAug-30-2018 04:45 AM
Dave5143 wrote:
You mentioned in an earlier post that your Blue Ox hitch shows 3 full links below the brackets. How many free links do you count above the brackets? Just curious. I usually have 8 free links on my setup with the F250. And yes I also do feel it when a truck passes me but for some reason the ones with the big slab-sided trailers don't seem to push as much as those pesky car carrier trailers. Beats me why.
โAug-29-2018 09:10 PM
โAug-29-2018 08:31 PM
โAug-29-2018 01:14 PM
โAug-29-2018 09:31 AM
goducks10 wrote:Pretty simple, 3.5L with Max Tow pkg 17" tires 17,000 lbs.; 18" tires 17,100 lbs.troubledwaters wrote:mike102 wrote:17,000 lbs
May be i missed it but what is the GCWR of the 2018 1/2 ton HDPP
Interesting that my 2010 F150 5.4, 3.73, 145"WB Max Tow (Not HDPP) was 17,100
โAug-29-2018 08:01 AM
โAug-29-2018 07:50 AM
โAug-29-2018 05:07 AM
โAug-27-2018 05:13 AM
parker.rowe wrote:demiles wrote:
This point you brought up is actually proof of what Iโve been saying in regard to the HDPP trucks. If the HDPP trucks could achieve sway damping and understeer gradient limits at a higher trailer weight the numbers would be higher, but theyโre not. This is the reason why when the GVWR increases GCWR decreases. Thereโs nothing about the HDPP trucks that will substantially increase TWR over Max GCWR/MT only trucks and Fordโs own towing guide proves it.
I still would want the HDPP if I was buying a F150 mostly for towing though...if only for the 3.73's and the bigger 9.75 rear.
โAug-27-2018 04:28 AM
demiles wrote:Totally false.
... This is the reason why when the GVWR increases GCWR decreases...
โAug-26-2018 10:10 AM
โAug-26-2018 09:10 AM
