carlislefamily2's avatar
May 29, 2020
F250 3.73 to 4.30 axle ratio
I have a 2017 F250 4x4 crew cab, 160" wheel base, 6.2l gas, 3.73 gear ratio. I am trying to see if having 4.30 axle ratio gears installed will make much difference regarding 5th wheel towing. I noticed that the Ford Towing Guide shows an increased max loaded trailer weight increase of 2,500lbs with the 4.30 gears as opposed to 3.73 gears. Also, if anyone knows the average cost of this gear swap, that would be helpful. We are looking at going from a trailer to a 5th wheel and could use the extra max loaded trailer weight that the different gears should provide.
Thanks....
