F250 Payload
HikeN2Mts
Looking at 2016 F250 XLT crew cab short bed trucks,gas model shows 2755 payload on door and diesel shows 2122 lbs with a option on it called camper pkg- upgraded front & rear springs and stabilizer bar. Is 2122 lbs the average for most F250 what options do you have if your is above that? The F350 had 3203 lbs payload, just thought 250 would be a little more with diesel,
18 REPLIES 18
RWDIII
My 2015 gas,4wd Xl work truck with sno plow pac has payload of 3200 lbs .
Only regret is not getting 18 inch tires
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
stickdog
The diesel engine weighs much more than the gas engine. F250 has a GVW of 10,000 if you move up to a 350 you can order one with a GVW of up to 11,500 so you could increase your capasity by 1500 lbs.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
downtheroad
Diesel engine weighs a lot more than the gas engine...the extra weight of the diesel subtracts from you available payload.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
HikeN2Mts
update: gas model was 3.73 rear end and diesel was 3.55
