f250 VS f350
Hondavalk
My daughter is looking to buy a new F 250 or F 350 and asking Dad for advice. She is looking at the 6.2 gasser. Considering how small the price difference is between the two, I'm looking for some learned opinions. Her yet to be purchased trailer will be a 2 horse trailer with living quarters. Typical trailer weights she is looking at will be around 7,000 pounds with a GVRW of 16,000. Guessing loaded it will be around 11,000. Any advice would be appreciated.
28 REPLIES 28
colliehauler
IdaD wrote:
colliehauler wrote:
Grit dog wrote:
Same truck, differnet springs. Doesnโ€™t matter.
Actually I think the 350 has a slightly heavier rear axle but itโ€™s not the limiting part of the equation.
Different transmission, F-250 has torque shift G, F-350 heavier duty torque shift is my understanding.
I thought the diesel F350 was the only version that was marginally different than the F250 on the axle and trans? Not sure. There's only recently been any distinction since the 2017+ trucks came out.
My understanding is the F-250 went to the torque shift G for 2017 and the F-350 uses the heavier duty torque shift.
IdaD
2015 Cummins Ram 4wd CC/SB
sgfrye
MFL wrote:
I think with the gasser, either would do the job, especially with the 4.30 gearing, that may require ordering. I do think in the new model 250/350, that there are a couple significant differences. I'm thinking the 250 gas has a lighter duty transmission now, compared to the 350 gas, or diesel versions. It also seems that the 350 gas has a heavier duty rear axle too, not just rating.
The 6.2 has been a good engine since it's beginning.
Jerry
X2
4.30 will probably require special order.
I bought a 2017 gasser f250 super duty last October. Love love the 6.2 engine. I now wish I would have ordered the 4.3 rear end because when you are towing gas mileage doesn't really matter. It tows our 7300lb TT with zero problems.
Unloaded it rides as well as a f150 in my opinion.
If I was towing that size horse trailer I would prefer a diesel Ford. From experience I would want more truck than I needed.
Campinghoss
I just sold my F-250 6.0 with 200K on it. It was a solid truck and did not give me any trouble. I would strongly recommend the F-350 dually with the 6.7 diesel. It does not ride harsh empty and as a matter of fact it rides better than my old F-250.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
colliehauler
Slownsy
To best of my knowledge the springs are identical except for extra overload which donโ€™t engage when empty.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
theoldwizard1
When empty/not towing the ride on the F350 will be worse.
A friend added extra springs to her F250 for towing her 3 horse trailer with living quarters. Tows great, empty ride ...
gmw_photos
As others have said I think you and she may be underestimating the weight of a LQ trailer all loaded up.
One of our horse trailers is a GN four horse slant with front dressing room, but it's NOT a LQ, and it's usually loaded out to close to 14K lbs going to a show. We use a F350 diesel dually tow tow it.
So yes, I second the idea that for a LQ, a one ton dually is best fit.
There is a reason why one ton duallies are called the "Kowgirl Kadillac"
Lexx
If I were her, I'd head straight into a F350 DRW with the diesel. If she's hauling a 16k lb GVW trailer, she's going to really be at the limits of a gas engine. The diesel will make her towing experience much easier and probably safer as well.
You'll need to look up the payload capacities of the SRW vs DRW of the two vehicles. I know that with the diesel F250, 16k is at it's very limit and possibly over it depending on the tongue weight.
The DRW will give her extra security when she encounters crosswinds and when the big rigs blow by her. It'll give her all the extra payload she needs.
If she wants bigger brakes (15.4 inch) and a 6 foot tighter turning radius, then the F450 would be the way to go.
You can check out the ratings using the Ford Towing Guide:
https://www.ford.com/cmslibs/content/dam/brand_ford/en_us/brand/resources/general/pdf/guides/18RV&TT_Ford_SuperDtyPU_Nov27.pdf
2017 Ruby Red Platinum F450 - my kids call her "Big Red"
2018 Grand Design Reflection 28bh
Grit_dog
Navigator
Navigator
tinstartrvlr
I've had both and considering the small price difference I would go with the 350. Extra payload capacity etc might come in handy down the road if circumstances change. Never hurts to have a little more than you need.
MFL
Nomad II
Nomad II
Jerry
BB_TX
You need to look at the loaded hitch weight of that large horse trailer and then at the payload rating for the trucks. You may well be into dually range to carry that much weight.
DaveF-250SD
Always go by the GVW of the trailer. For any weight close to that, she should go straight for the F-350.
2004 F-250 XL Super Cab short bed 4x4 V-10/4R100
1977 Chevrolet Scottsdale C-20 Trailering Special 454/TH400
