F450 vs Ram 3500 DRW tow vehicle
___M4Lourenco
So the wife and I are moving to the full time RV lifestyle. We just purchased a 42' toy hauler this weekend, with a GVWR of 20K#. Now I'm looking at a tow vehicles. I'm considering either purchasing a new 2020 Ford or Ram, but leaning more towards the Ram, after doing some homework and my own research. Before I make my final decisions I wanted to hear the RV community opinions between these trucks. I greatly appreciate your comments.
Thank you!
113 REPLIES 113
FishOnOne
Cummins12V98 wrote:
"Ram DOES offer a F450 equivalent... its called the Ram 3500."
HA, so true!
HA, My statement still stands! :B
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Grit_dog
Navigator
Navigator
^ Lol
Cummins12V98
HA, so true!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blofgren
spoon059 wrote:
Cummins12V98 wrote:
Troll wrote:
If Ram would offer a F450 equivalent, you can bet your bottom dollar cummins12V98 would be all over it and would be touting all it's glory ever day on this forum.
Not a chance! WHY pay more for insurance and tires? I tow more than MOST anyone on here with zero issue!
36k combined with 6k pin=GOLDEN.
:B
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Huntindog
MikeRP wrote:
You can have a normal bed put on a Ram 4500 or 5500.
I checked into this when I was shopping for my current truck.
It has been done, but....... The bed needs to be stretched about 10". That is a totally custom mod, which equals EXPENSIVE.
I did see some pics online, and it looked good, but IIRC, the company that was doing them folded.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Me_Again
He could not get his job done with the lower carrying capacity of the F450 vs his 3500 RAM.
spoon059
2015 Ram CTD
2015 Jayco 29QBS
Cummins12V98
LOL... Yeah...OK... :W
m
Ok you got me! 450 has tighter turning radius. Not sure how I have gotten along
FishOnOne
Grit_dog
Navigator
Navigator
So 4x4ord has a point with the overall gearing (Trans od ratios and rear gears) and power the engine puts out.
But What he is actually saying is the 4.30 geared Ford doesnโ€™t โ€œneedโ€ that low of gears and there may be a small fuel consumption advantage to the taller gears when cruising empty. I doubt youโ€™d see any measurable difference hooked up heavy. Any small efficiency on the engine end of lower rpms will still have to drive through taller finals.
Likely a wash.
My old Mega is a good example of what Iโ€™m saying above. Even with taller than stock tires, the shallow OD ratio puts it at 2000rpms just a little over 60 mph and cruising at 85mph is like 2600-2700 rpms. Truck will do it all day long but Iโ€™ve driven similar trucks with a deeper OD and it seems the fuel economy is not much different.
So many conditions affect fuel economy, the gearing is only a small part of the equation.
Regardless of what the president of the Ram mafia says, by the numbers a new 4.30 450 Powerstroke IS king of the hill right now on all fronts when it comes to capability.
Cummins12V98
4x4ord
^^^4.30 gears with the 7.3 would make more sense.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
NRALIFR
When Ford makes the F450 pickup available with the 7.3L Godzilla, thatโ€™s my next truck.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
Geo_Boy
Donโ€™t forget the new GM 4500, nice truck.
4x4ord
How heavy is the heavy RV you're talking about? If you're talking about a 34000 lb RV then yes a F450 with 4.30 gears is the truck for you. If you've got a 20,000 - 25000 lb RV the F350 with 3.55 gears is going to be a much better choice. The F450 with the 10 speed transmission runs out of cruising gears at 50-60 mph. The 2020 Powerstroke makes 320 hp at 1600 rpm and it only takes about 140 hp to pull a large rv down the highway at 70 mph. The F450 would be in 10th gear at 2000 rpm doing 70 mph.
B&W Companion
