crazyro's avatar
crazyro
Figuring out switches
Anyone with an Antigua here? I have three switches on the wall by fire extinguisher and only one operates anything that I can figure out. The far left one turns galley lights on (great at night for going all the way to the back of the coach to the bathroom). The other two... don't seem to do anything. I tried taking the cover off but didn't want to break it. I'm assuming it just snaps on? If the other two aren't wired to anything, I'd like to add some LED lights above steps and use one of those. Any ideas? Thoughts?
  • And once again you guys come through. Thanks to Soundguy and Geodude, I found out at least where to look for burned out bulbs (hence why nothing was happening when turning them on/off).
  • Have you found the switch(s) for your outside lights? If not, then the mystery switches might operate outside lights which are not working. Check your outside bulbs.
  • Had an Antigua 215sso 10 years ago. One of the three switches also lit up the dump valves. Very handy at times.
  • You just have to turn them on and look everywhere.
    As an example, I have a couple of switches next to the door and one of them turns on LED lights at the outside end of the awning. You would have no idea unless the awning was out.
    Would probably help if you identified your trailer as a 2006 Starcraft Antigua XLT M-305QBS. PM forum member Geodude as he had this same model for several years, perhaps he'll remember what these switches are for.
