First Camping Trip With Adventurer 116DS
Mike3
I took my new TC on it's maiden voyage to Bristol, Tn for the NASCAR race this weekend. Spent three nights there and I'm happy to say that everything worked flawlessly. I had previously added a memory foam pad to the bed so it slept great. Although getting up/down from the bed in the middle of the night for a bathroom break requires more effort than I'd like, might have to make a step to use at night. It was hot so I needed the a/c and the Honda 2000 did the job without complaining. It used a tank of gas every 4 to 5 hours but I was prepared for that.
The wet bath worked fine for me. The shower curtain allowed me to cover the toilet and the entrance door and still have plenty of room so as not to hit the walls while showering. I did soak the toilet paper the first time, LOL. Afterwards it took about a minute to wipe the walls then I turned on the bathroom exhaust fan and closed the door, no issues.
With the big windows and two slides it felt very roomy. During one rain shower there were four big guys inside and no one was cramped. My brother was next to me in a 25' TT with one slide and it did not feel any more spacious than the TC. The rig attracted a lot of attention. You would not believe how many people stopped and looked at it while pointing and discussing it with each other. Many came up to ask questions or comment. A few asked to see inside and they were amazed that all that could fit in a TC. I'm sure a few had less desirable comments but were kind enough not to say them to me.
The only issue I had was leveling the truck. As you can see from the pics below the terrain is rolling hills and I was on a spot with a significant left to right AND rear to front slope. I had four 18" 2X12s with metal ramps, 4 12" 2X12 blocks and two HD yellow drive on multi tiered ramps... not enough. After about 30 minutes of trying to make that work I removed all the blocking, removed the fast guns and used the jacks to level the camper. That worked great except my rear door was really high. I'm curious how many of you level using the jacks rather than blocking?
So I am now an official member of the TC club. I can see now that my Fiver is going to be very jealous.
Campsite in a field next to the track
Bristol Motor Speedway
2017 Entegra Anthem
2013 Honda CRV Toad
2013 Road Glide Ultra with a HydraLift
18 REPLIES 18
jimh406
Just to make sure everyone knows, be sure to unhook the tie-downs if you use the jacks to level the truck/camper. I don't although I've used them to stabilize the rig in strong winds.
I use the lego block type blocks but also have some home made 2x8s that are stair stepped down. I've got a bit of an issue with only one set that I have to workout now that I have a DRW in the back instead of a SRW. One more disadvantage of a DRW, I guess. ๐Ÿ™‚
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
campn4walleye
What a beautiful setup! You're in for a wonderful time of TCing.
2011 Adventurer 910FBS truck camper,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD,4x4,LB,CC,auto,3.73 axle,General 17" on/off rd
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
ZRX-Steve
kohldad wrote:
...Learning to level get easier, but no matter how could you get, you will always find a site that takes forever to get it right.
I never use the jacks once the camper is on my truck. All I carry is two 6x8x10 blocks, four 2x6x16", and a stack of eight leveling blocks. I use two 2x6 beside each other because I got tired of my 2x12s splitting in half after they dry out. I can use the block in any direction I need and have even learned how to use the leveling blocks on top of the boards for increase height. My wife was real nervous the first time I used a block on the 10" side and three leveling blocks on top of it. I pull up enough that the 2x6 becomes level with one end off the ground. But I explained that in 4wd-lo and granny gear plus the e-brake on, the truck wasn't about to move. After a couple of hours of seeing how steady the truck was, she quit worry about it. I'm also not paranoid about making sure the suspensions is all compressed the same. I have no problems having an axle compressed more on one side than the other. After all, that is part of the reason of the suspension.
With regards to the step being high, just turn around and it would be closer to the ground. May also have been easier to level.
Why don't you use your electric jacks for leveling?
2014 Lance 1191, 00 F350 DRW, 7.3, Auto, aftermarket intake/exhaust/transmission (pan, cooler, valve body),Gauges, PHP Hydra Chip. Supersprings, HD Timbrens, Sumosprings, Front+Rear 1.5โ€ Swaybars, Monroe Gas Magnum Shocks, 19.5" Vision, Centramatics.
bobndot
I use ramp blocks under the wheels ( like Billtex) , that allows the stress of the campers weight (5000#) to fall on the truck suspension. You could use the jacks to stabilize (fine tune) the rig but only use very little pressure, you are just stabilizing it from rocking.(Jumbo Jet)
Using the jacks alone makes the camper too tall if you are lifting out of the bed , stressing the jacks as well as the mounting plates. It's not intended to be used that way for long periods of time.
When people remove campers completely from the truck, they lower them as close as possible to the ground , that does not stress the jack leg or the mounting.
You can see that in pics of campers that are off the trucks. The campers jacks are not extended 3-4 ft.
One other possibility to occur is soft dirt under a jack. As it settles or in a heavy rain, the camper can sink in any corner and become off level, sometimes to the point where the jack leg bends or the mounting plate lets go .
We are talking a lot of invested money here , I would try to limit the possibility of something going wrong.
In your case, the camper would fall into the trucks bed containing it but damage could be done to both camper and truck.
There are some pics and rv net threads showing what happens when a jack lets go from being stressed.
JumboJet
Not to hijack your thread, but here is my picture from the March Bristol race at the All American campground. Attendance was poor. Weather was cold and wet.
I always try to level the truck the best I can and then use the jacks.
bikepsych
Ditto on using camper jacks to level it. It provides more stability than when not using them as the springs and shocks on the truck allow a lot of sway...if you know what I mean.
BG
hedge
I never use the jacks seems like that would be a pain compared to driving up on some blocks. I use the tri-levellers and back up a step at a time until it's level. If it's off sideways too then one side gets a head start.
I actually like the rocking effect if it moves a bit.
2017 F350 Platinum DRW
2013 Adventurer 89RB
Fastbrit
I learn here that when you use the jacks to level the camper you have to watch for the pendulum effect. The front jacks are more sensitive to that since they are attached to the camper only at one end. This is why I always try to level the truck as much as possible and then do the fine tuning with the jacks.
1997 Dodge Ram 3500 CTD. Timbrens all around, Bilstein shocks.
2014 Chalet TS116
brholt
To level a bit we use the jacks (often we don't even have to release the fast guns). For worse terrain we will use blocks, and if it is really bad we have used both.
CaFordGuy
I use the camper jacks exclusively to level the camper. And I camp on some pretty un-level spots when boon docking in the National Forest. I do carry a separate step in case the rear end gets to high.
Also have chains to extend the tie downs which I use to steady the camper if it get a little high.
Been doing this for 15 years.
Mike3
Other than the additional work/time it takes to loosen the fast guns, level with the jacks and then do the reverse when departing is there a reason not to use the jacks?
Those of you with more experience, how long does it take to unload the camper and to load it when departing?
2017 Entegra Anthem
2013 Honda CRV Toad
Fastbrit
Very Nice camper! When we were shopping for a truck camper last winter the 116DS was on our short list. My wife loved the rear kitchen. When at campground We drop the camper most of the time. But when we park only for the night (boondocking) We level the truck the best we can and finish with the jacks of the camper.
20140601_153958 par steevesdbs, sur Flickr
2014 Chalet TS116
billtex
Yeah...that's what I was thinking...
A couple of suggestions;
For the shower, we use a quick dry shower curtain (nylon/polyester?) instead of vinyl. It does dry quick with the fan on and it is washable...
For levelling I use 6"x6"x 18" mitered. If that doesn't get me close enough I'll move or dig some holes.They probably wouldn't like holes at the speedway!
BTW; nice rig. You are going to love the TC...
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
kohldad
Very glad your trip went well. Learning to level get easier, but no matter how could you get, you will always find a site that takes forever to get it right.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
