โJul-23-2018 01:09 PM
โJul-26-2018 02:35 PM
โJul-25-2018 02:17 PM
โJul-25-2018 12:18 PM
mat60 wrote:trail-explorer wrote:Ok.. Get a 4-way lug wrench. ๐mat60 wrote:
Get a 4-way
a 4-way what?
โJul-25-2018 10:57 AM
โJul-25-2018 08:08 AM
โJul-25-2018 07:28 AM
โJul-25-2018 07:20 AM
โJul-25-2018 07:05 AM
Jackfate wrote:Thanks for the tip. Couple of years ago I looked all over for a saddle that would work but will see what some trailer fab places have. I thought I could just cut a piece of pipe lengthwise but the OD of the U-bolts is too far off standard pipe IDs. Buying a pre-made saddle would def. be a lot easier.myredracer wrote:
One of these days I'm going to make a custom saddle from steel pipe for the jack so it fits perfectly under the U-bolts and can't slip. This jack makes it easy for inspecting/serving brakes & wheel bearings at home.
If you can find a place that sells trailer fab stuff you can get a axle perch just like the one on your Springs. Weld that to a 2โ long piece of pipe that slides over the top screw of your bottle jack.
โJul-25-2018 07:00 AM
โJul-25-2018 06:43 AM
myredracer wrote:
How does a regular bottle jack fit under an axle? I ended up buying a double ram Torin jack that is about 6" tall collapsed (14" max extended) so it would fit under the U-bolts along with a piece of 2x4. Some axles are under the springs (like ours) and some are over which are safer to put a jack under. One of these days I'm going to make a custom saddle from steel pipe for the jack so it fits perfectly under the U-bolts and can't slip. This jack makes it easy for inspecting/serving brakes & wheel bearings at home.
If we didn't have a jack and had a flat on a trip, I'd be making a ramp from our lego blocks and putting one on each side so the trailer doesn't have to tip over.
โJul-24-2018 05:44 PM
โJul-24-2018 01:36 PM
โJul-24-2018 01:32 PM
โJul-24-2018 12:23 PM
rbpru wrote:Makes some sense but what if the bottom of your frame is like 24" above the ground? Our is like that and I did try jacking the frame up at first but found I needed to use cribbing to get the jack up high enough to reach the frame. If a person didn't realize this and have some suitable pieces of 2x4 or 4x4 with them, they could be SOL. Jack stands would need some cribbing too. And def. don't jack a trailer up and not use jack stands. That could be a lot of cribbing to carry around - providing you don't accidentally use it for firewood.
So, they just tell everyone to put the jack on the frame.
