Feb-08-2014 11:57 AM
Feb-12-2014 05:43 PM
rhagfo wrote:rhagfo wrote:jerem0621 wrote:
7.3's are naturally loud. Add a custom exhaust and you can get mind numbly loud.
Take it to a shop and have them take a look and give an opinion.
Thanks!
Jeremiah
I doubt that much of the noise is from the exhaust!! The 7.3 and 1st and 2nd gen Cummins are naturally noisy due to the single event combustion.
You will get over it once you tow with it.Okie1 wrote:
I will agree that 7.3 Powerstrokes are very noisy engines but NOT from the exhaust. You probably don't have a muffler at all. There is no way you can hear any exhaust noise over the engine noise in mine....
He will soon learn that the early diesels are just noisy, no matter the size of the muffler the single injection event, is just plain loud.
:B
Feb-12-2014 04:13 PM
Thanks!
Jeremiah
Feb-12-2014 02:45 PM
Feb-12-2014 12:59 PM
Feb-11-2014 11:14 PM
redfire2002 wrote:
I have an egt gage and I assure you temps from stock to a 4" is a 200 degree difference. A muffler is all he needs. You don't want to go from a 4" down pipe to a 3" half way back. It's like an hour class, sand will flow fast at first then slow down as the opening gets smaller.
BBURD wrote:
Purchased (new to me) Ford 250, 7.3 ltr turbo, 126000 miles. Exhaust has been modified and has big tip. Wife says too loud. (I have to agree) Saw 4.5 inch tip silencer that attaches to tip of exhaust to supposedly quiet it down. Has anyone used? Will it restrict exhaust too much and inhibit performance? Etc Thanks
Feb-11-2014 11:09 AM
Wes Tausend wrote:
Just reasoned speculation on my part, but it seems if one has 4 inch exhaust all the way back, that just about all significant restriction would already be removed by the 4 inch forward pipe, even if a quiet stock muffler were retained.
The increased 4 inch pipe volume ahead of the muffler should be fairly sufficient to absorb the added hot exhaust expansion, especially at the low 100-200 hp boost levels usually attained by street trucks. By the time the muffler is reached, the exhaust is cooled and already contracted quite a bit. Once the exhaust gas is cooled, it no longer needs the volume it did while hot and, of course, the turbo power has already been extracted.
I'll bet there is very little dyno difference in 4 inch all the way back as opposed to half-back. Of course, if I were a truck accessory company, I wouldn't want to lose lucrative "plumbing" sales. As usual, there is more money in selling overkill.
So if the OP has an exhaust temp gauge, it would be interesting to see if downpipe temps don't remain about the same with no other changes except the muffler.
Wes
Feb-11-2014 08:04 AM
Feb-10-2014 11:16 AM
Feb-10-2014 10:10 AM
Feb-09-2014 01:50 PM
Feb-09-2014 12:59 PM
BBURD wrote:
Thanks much fellas. I have been to sites for MBRP, SSDPro, etc. Right now, (having just bought the truck), I can't see 5-6-7 hundred dollars for whole system but less than 100 for muffler that will stop the 'drone' and quiet exhaust would be ok. Thanks for the help and references to products.
Feb-09-2014 10:01 AM
Feb-09-2014 07:45 AM
Feb-09-2014 06:14 AM
Feb-08-2014 06:23 PM
