โFeb-05-2019 04:55 AM
โFeb-08-2019 03:32 AM
ib516 wrote:patperry2766 wrote:
maybe I didn't catch it....but is it replacing the 6.2L completely or is it an optional engine in addition to the 6.2 & 6.7D?
The 6.2L stays as the base engine in an F250 only, and comes mated to the 6 speed auto. The 7.3L and 10 speed will be the base in the F350 and up.
โFeb-07-2019 05:26 PM
Groover wrote:
I think that one of the big drivers for keeping this engine small is the class C motorhome market that is based heavily on the V10. The 3 valve version of the V10 won't fit in the van front end and even the 2 valve can be difficult to service. On my 15 passenger van version the first step in changing the spark plugs is to lift the body off of the frame to get room to work. I would guess that on a motorhome that could be even more challenging.
โFeb-07-2019 04:33 PM
โFeb-07-2019 12:57 PM
โFeb-07-2019 09:53 AM
โFeb-07-2019 09:15 AM
โFeb-07-2019 07:37 AM
โFeb-07-2019 05:26 AM
โFeb-07-2019 04:47 AM
BigToe wrote:parker.rowe wrote:BigToe wrote:
The 6.8L V10 has driven the RV industry for the last 20 years... in Class A motorhomes, Class C motorhomes, Class B vans, E Series ambulances that rush us to the doctor, and F Series trucks... from the F-250 all the way up to the F-750.
For over two continuous decades in a row, the overhead cam 6.8L Triton V10 has provided the power and proved itself... without a lot fussyness or fan fare.
Where's the love?
I don't think anyone said anything negative about the 6.8...but time marches on.
Hopefully this engine will be a worthy successor.
Carbed big blocks drove the RV industry for years before the 6.8 came around, but no one is looking to go back to those.
Yes, but the overhead cam, coil on plug ignition, sequential multiport fuel injection, long intake runner Triton V10 was a very obvious leap forward in engine technology over the carbureted big blocks in just about every engineering aspect and angle.
What's different about the push rod 7.3L is that Ford appears to be going backward technologically (presumably to save production costs), while selling the new motor as a leap forward. It isn't.
Even Ford's chief engineer for the engine, Joel Beltramo, made it clear in a variety of ways that it was a step backwards on a number of fronts. Listening to his responses in the interview, he repeated a mantra that I will paraphrase as something to the effect of "we didn't think it was needed".
So why bring up the 6.8L? Because anyone looking at Class 4 to Class 7 chassis cabs at this 2019-2020 juncture may want to consider a purchase now, in order to get the tried and true Triton V10, that has proven to be reliable despite it having more complex valve, cam, and injection technology, and has proven to be potent despite it's smaller displacement.
The new 7.3L block is a step backward from today's casting materials, being made of regular old grey iron rather than compacted graphite iron. It is a push rod motor, rather than overhead cam. It isn't direct fuel injection, like the new 6.6L gas motor from GM that it will be pitted against competitively.
And the reason for all these backwards steps was because "it wasn't needed" for the application. And I'll bet it is a cheaper to produce, especially since the Triton V10 lost it's two Triton family stablemates it shared many common components with... 5.4L and 4.6L, both shuttered by 2014... that vastly expanded the economies of scale that justified production of the V10 Triton motor.
With the volume of the smaller sized Triton motors out of the equation, the per unit cost to produce the more complex V10 had to be a motivating factor in considering an entirely new solution with a simpler valve train. Selling the concept of "simpler" as a reliability benefit to buyers is an obvious way to explain away dumbing down the engine... but the fact remains that the more complex 6.8L was already reliable.
While Andre did broach the subject of any relationship that the 7.3L has with the 6.2L, I'd have to listen again to see if Beltramo indicated whether the 7.3L is based on a stroked and poked 6.2L. I don't recall how that question was answered, of if the topic derailed on a tangent.
Anyway, with 20 years of solid commercial service track record behind the Triton V10, other than that brief period of spark plug spitting that got resolved 15 years ago, it is difficult to understand why Ford is making a change to a motor that is actually NOT bringing 20 years of engine technology advancements to the table, but instead is going backwards a few pages.
I was at the Ford manufacturer's booth at a automotive industry event back in 2001, and heard some Ford engineers way back then muttering about wanting to go back to push rod V8s. This was when the Triton family was the staple motor in many Ford products, and 5.0 of the previous era was had been retired. In particular, the Ford folks I was talking to were a small subset of performance oriented guys who were responsible for making the Mercury Marauder happen. I probably understand just as little today as I understood then why the push for push rods.
But now, Ford will have pushrods, a valve train that in theory is more likely to produce more low end torque at lower rpms, which is the more likely call of duty that a truck buyer would demand from an engine in the intended applications... at the expense of a more mechanically efficient valve train, total valve opening area, and higher rpm horsepower delivered with smaller displacement.
That the 6.8L V10 sees duty in an F-750 at 37,500 GVWR, with a V, not a C, really is a testament to a great motor. However inexpensively Ford manages to built the new 7.3L, it will have some big shoes to fill. Despite the tempting on paper combo of a 7.3L with a 10 speed transmission, I think I'd still have a tough time deciding on whether it is better to grab a 6.8L while one still can.
โFeb-07-2019 04:40 AM
โFeb-07-2019 02:48 AM
ACZL wrote:
In the 90's, GM's 7.4 was a 454 and I think Ford's 7.? was a 460. Am I right? Granted they didn't have the numbers as they will today, but displacement wise....the same. What was GM's 8.1 back in early 2000???
โFeb-06-2019 09:39 PM
โFeb-06-2019 07:59 PM
Where's the love?
โFeb-06-2019 07:38 PM
Where's the love?
โFeb-06-2019 06:14 PM
Where's the love?
