โApr-26-2013 01:18 AM
Porsche or Country Coach!
โMay-01-2013 03:16 PM
Golden_HVAC wrote:
This might prevent a current problem, the transmission overheating while backing up with a larger fifth wheel attached. The transmission heats up mainly because it is not turning more than a few dozen revolutions on the output shaft in a minute, but the input shaft needs to turn 900 - 1800 RPM to develope enough horsepower to move a larger trailer onto leveling blocks, or to get it up a steep driveway.
Fred.
โMay-01-2013 02:06 AM
โApr-29-2013 09:30 AM
โApr-28-2013 04:27 PM
โApr-28-2013 12:46 PM
h2guy wrote:h2guy wrote:rjstractor wrote:h2guy wrote:
And on these 9-10 spd trannys, I'll bet you'll never see one in a HD diesel powered PU. Too much stuffed into a small space can't possibly allow much torque.
???? The up to 18 speed transmissions in OTR trucks seem to handle 2000+ ft./lbs of torque pulling over 100,000 lbs. just fine. A smaller, fully automated version would work well in a pickup.
I don't think so. Those trannys are MASSIVE, as is everything else on an HDT. And they use a splitter to get 18 spds, not gearsets. And they're manuals, not automatics.
I just don't think the metallurgy and size constraints under a PU will allow it.
The Ford's 4R100 (100 for the 1000ft lbs of torque rating) is pretty big already.
โApr-28-2013 12:45 PM
โApr-28-2013 12:43 PM
โApr-27-2013 01:24 AM
โApr-26-2013 08:07 PM
โApr-26-2013 07:26 PM
โApr-26-2013 05:39 PM
โApr-26-2013 05:32 PM
โApr-26-2013 04:44 PM
โApr-26-2013 03:56 PM
