SkimmerBob's avatar
SkimmerBob
Fresh water problem with water overflow while being towed
Just got back from second trip in '14 Jay Flight 267 BH, The first trip was about 90 miles and when I got there and was almost done setting up the DW said the Fresh water says "EMPTY" , I said I thought I filled it but maybe not there was a lot going on for the "maiden voyage " So I carried a couple cans of water from the nearby spigot. That filled it to 2/3rds so we were good. This trip we were at a CG with water hook-up for a couple nites then we were going to a state CG with out just 17 miles down the road. Now the same thing happened this time it said 1/3rd & everyone knew I filled it. So I crawled under and was able to see the level thru the tank side it was just above the 1/3rd sensor. I also noticed 2 overflow hoses on the side next to each other. so I'm thinking that doubles the water flow out sloshing out of the tank on the winding twisty road.
Against my better judgement I bought this unit from a very large dealer with several locations. I called the service dept. from the CG just to ask if this is a common problem with this unit. The service manager told me he never heard of this problem before and that most people don't use there fresh water tank they usually hook up to city water. I found this a very comical answer and thought I should share it.I probably use my FW tank 96% of the time.
Anyone else ever have this problem? I am thinking I'LL just put a couple valves on the lines and close them while traveling
Sorry for such a long post.
