jburkett84's avatar
jburkett84
Freshwater is full, but might as well be empty....?!?!
Hey there, newbie to forum and to the full-time camper life ... so please be gentle!
The camper ...
Bought a 2013 Keystone Cougar 30FVK, enclosed tanks and such. This month we've been setup outside of Columbus, Ohio - where the last few days have seen some SERIOUS cold temperatures ... (especially compared to our hometown of Newton, Mississippi) ... Looking forward to getting down to Texas this weekend!
The problem ...
I've got our water hose setup for cold temps - heat tape, insulation, pipe insulation, so I'm getting a fine water supply from that hose. (No problem here)
The day before last I filled up the freshwater tank and tried to pull some water from that tank. You can hear the water pump running (it's got a steady "burrrrrr" sound - I'm sure that's the technical term) however, when I open the faucets/toilet/etc no water comes out ... if I switch back over to my self-created heated water hose, water supply is fine.
SOOOO YEAH, never had a problem the last few months getting water from the fresh water tank ... weird.
Here's what I've checked so far ...
- Power levels (based off the manual that came with camper) are fine
- Water supply in tank is "full", I made sure I wasn't filling it with the drain open
- Checked basic wires to/from the pump to make sure I didn't catch a hitchhiker (mouse) and it didn't chew through the wires
Having said all that ...
Is it possible that the supply line from TANK -> PUMP is frozen? If that's the case, is this something to worry about, a way to "alleviate" the problem? Or is there another culprit that might be causing a problem...?
I've checked the forum for about the last day for this specific problem, but couldn't find one exactly like this, so I'm kind of concerned and interested to see what you think! Being a newbie I'm all ears and ready to learn ... soooo let me have it!
