When I got started in all this weight distributing/anti sway hitch choice thing I was focused on....simplicity. Way back, many of the snap up the chain hitches did not allow you to back up with the chains attached. I also didn't "like" the idea of snapping these chains into position and I really was confused about the friction bars being used. I got all sorts of nebulous information. Only tighten them as much as you need was one of my favorites. What? How do I know what I am going to need?
I went with the Equalizer. It is easy to adjust and once you have it dialed in, it is a quick hook up. I personally believe that add on friction bars can offer up enough safety and many still use them. When reading threads like this one I am still a bit confused. Should I use one or two? I have been using these for "x" amount of years and they remove 90% of the sway. Well, what about the other 10%?
I like mine. I have over 55K miles on my current without any issues of sway. I will stick with the Equalizer.
