- Cummins12V98Explorer IIIDoubt it really makes any difference. BUT you would most likely be better off selling yours and buying a DRW of your choice.
- notevenExplorer III
I should have mentioned it’s a cab and chassis truck with aluminum bed etc how I like it I don’t want to sell and buy again.
Ford c&c Trucks use the same rear axle housing/hubs with extensions and longer axles near as I can figure.
A second stage upfitter engineer can re-rate the truck in Canada. - blt2skiModeratorMy 89 and 05 had extensions on front axle iirc. My IHC on the other hand, was made for the reverse off set.
I don't personally see an issue with extensions.
Marty - rhagfoExplorer III
noteven wrote:
Does the extension used on the front wheels of a dually to mount the all position wheel in the negative offset apply any additional forces to the bearings vs a single wheel truck with a more neutral offset?
I am considering converting my F-350 single wheel to a dually...
No the reason for the extension is to center the wheel over the bearing.
To Ron’s concern, I would agree if standard F350, but as it is a CC, and it can be re-certificate see no reason not to. - notevenExplorer IIII figured it would be ok I don’t see the roads littered with dually trucks with the front wheel fallen off...
A local tow operator told me Ford C&C single wheel and dually have same rear axle with an extension kinda like the front. I’m going to dig around some online parts diagrams ...
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 13, 2025
