Frontal Sq'
mountainkowboy
Is there a formula for calculating it for a curved front TT? I called Coachmen to get the frontal sq' of the 192RBS during my researching and they don't have any idea. All they could tell me is "if it was flat it would be 56sq'" Well it isnt flat, in fact it's only flat to the end of the diamond plate then takes a curve to meet the roof. Anyone know???
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
53 REPLIES 53
LVJJJ
rbpru wrote:
If there were a shape or gizmo that made enough of a mileage difference without effecting the utility of a TT, it would be standard on every semi on the road.
There are a few items that help but nothing that amounts to a major break through; except perhaps for an electric or hybrid powered pick up.
Some semis have air foil extensions at the rear, on the top and sides that angle in to help it break out of the air stream. And I've mentioned before that many have the long under side panels directing the air flow out in front of the tires to control turbulence.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
Slowmover
I agree, and yes air flow matters, especially in a controlled environment, such as wind tunnel tests, or still air. In the real world, we are towing our boxes in varying wind speeds, and direction. There is not much help for angled or side wind, which is worse than towing into a straight-on headwind.
Jerry
The point of aero design for a TT is just that: crosswind handling. No squared edge box has it. Wind force piles up โ€” trapped โ€” and increases the length of the TT. High ground clearance and open undercarriage makes it worse.
Enclosed undercarriage, low ground clearance and radiused edge (curved) sidewalls allow the wind to pass. Exerts a pull versus a push as it goes over. Much easier to deal with.
I can continue down the road still with one finger on the wheel when the boxes are having to pull over. Thatโ€™s not any exaggeration.
Besides an indefinite lifespan itโ€™s the reason to have one. Less HP in every situation, and always better handling when it matters most: crosswinds.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
Old-Biscuit
mountainkowboy wrote:
Old-Biscuit wrote:
Use the 'flat figure'.....width x height
Curves will just make it less.
Besides..frontal area is least of concerns.
Trailer GVWR, tongue weight are more important factors when it comes to 'can it be towed'
So would that be "I don't know? I didn't ask if I can tow it, I was looking for a formula.
Actually I do know......
Here's the formula for a curved surface. Have fun!
Curved surface formula------- 2 pi r^2 + 2 pi r h.
And after you get it worked out you will realize it doesn't matter all that much.....just use the simple 'flat' formula ----W X H
That is true I got the formula PM's to me and it isn't a significant amount of change. As others have stated the curve is mainly for less drag while towing.
So what is the issue :H
MFL
Nomad II
Nomad II
Jerry
rbpru
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
TomG2
drsteve wrote:
I always thought those were about keeping the back window clean. In the days of the old station wagon, gas was 25 cents a gallon. Nobody cared about MPG.
When we made one hundred dollars a week, $.25/gallon gasoline was just as expensive as $2.50/gallon when earning a thousand a week today. That is the cruel lie of inflation. People did care and the Economy runs were very popular.
drsteve
LVJJJ wrote:
You're all worried about the wrong end of the TT. If the TT is a flatback the vacuum created by them acutally tries to suck the TT backwards, so, as I did, install an air deflector to direct the air flow down the back of the TT in order to help it detach itself from the air stream, that's where the major drag is.
I've heard this...has anyone tried the airtabs? I think that's what there called. Was your deflector like the old station wagons used to have? Redirecting the air off the roof down to break up the vortex?
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
LVJJJ
I could care less about any savings in mileage (I still say if you're worried about gas mileage, you'll not have much fun RV'ing, towing sucks up gas).
What the aerodynamics of the Trail Cruiser does for me is allows me to tow a larger heavier trailer with my anemic low compression engined '94 GMC Suburban.
Used to towed a 22' '04 Tahoe Lite (yeah right) with a front profile that was flat at the bottom 18" or so then sloped steeply back to the roof, and had the poorest design feature ever, a flat back. weighed about 5000 loaded. The Trail Cruiser is 26' 11" long, weighs 4800 (certified scale) lightly loaded and is much easier to pull. Probably 5500+ loaded.
When we decided we didn't like the 48" wide double bed, underneath a bunk (hard to get in and out with bad knees, shoulders, etc., and since we had had a 30' Trail Lite a few years ago, we decided that we had to find a certain Trail Lite or Cruiser with a queen bed and couch slide. Took about a year, with 700 mile trips to see junk, finally found one 35 miles away.
2008 HHR
qtla9111
Some of you would make excellent detectives and Iยดm glad you donยดt live next door.
Instead of guessing what the OP has in mind, why not just ask the question?
He may not answer now as it looks like heยดs under investigation for asking a simple question that no one here has the answer to much less the manufacturer.
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
bobndot
I thought about them but didn't bother after researching.
Air tabs have been tried. People I met that have used them didn't notice a mpg advantage but a cleaner rear of the RV . They also might help a little with stability in the wind but IMO, it would depend on the TT they were installed on.
As far as measuring MPG, the road, weather conditions would need to be identical to measure accurately using specific equipment other than someone's fuel gauge and how many gallons they had to pump back into the tank. Take those opinions with a grain of salt.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23208771.cfm
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23094344.cfm
mountainkowboy
2011 Ford Ranger
1987 HD FLHTP
mountainkowboy
MFL wrote:
The OP could likely get by, using his Ranger, if towing shorter distances, at reduced speed. I think this is his plan, since he has the more capable truck for his long distance towing.
Jerry
Exactly, I think the farthest we've ever gone doing local or weekend stuff is 170 miles, and you don't need much stuff for a 3 or 4 day weekend. I would suspect that there will only be 200 or 300 pounds in it behind the Ranger. Plus I have a wedged bed topper, that might help bump the air a little higher before it hits the TT.
2011 Ford Ranger
1987 HD FLHTP
GrandpaKip
Some TT's like the Trail Lites and Cruisers are rounded down at the back top, and the bottom is angled in so air coming off of the smooth bottom is deflected up at an angle helping it break out of the air stream.
Airplanes are big in the front (although streamlined) and taper to a point for a reason, even though it seems like it would be better if the point was in front for no frontal air pressure.
My old Trail Lite was like that. However, I have noticed no difference in mpg or towing between it and the Skyline Dart, which is all right angles in the rear. But the front of the Dart is rounded and the Trail Lite was flat. Maybe a trade off between the two?
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
rbpru
As MFL pointed out, my buddy knew his Dakota was not the ideal tow vehicle, but it was what he had and it was a limited tow. He really really liked the bigger TV. ๐Ÿ™‚
Also as I mentioned, almost every modern TT is within a few inches of every other, they all have about the same roof bumps like vents and AC and they all have flat backs. Airstreams and some of the shell type TT's are better but I doubt that frontal area is the reason people buy them.
TrailManor and the old HiLo had the right approach but the majority of the buyers simply do not care enough about it to be a concern to the market.
