debkauf
May 27, 2024Explorer
Furnace won’t turn on
- our 2016 Chalet Arrowhead’s Atwood furnace won’t start. Battery charged, full propane tank, other appliances working. Where’s the reset located? Any other suggestions?
Check the thermostat, and remove any obstruction if there is, in the furnace.
Have you checked the cage-fan to see if something has gotten inside of it. If the cage gets stuck the furnace will not ignite and run.
I believe some of the Atwood furnaces of that era had a reset switch on the lower right of the fan motor housing. Some had exterior access panels, some did not. If it does not, you may have to be a contortionist to reach it. All I can offer, hope it helps.
