โAug-24-2016 12:13 PM
โAug-26-2016 11:03 AM
โAug-25-2016 03:09 PM
โAug-25-2016 08:46 AM
โAug-25-2016 07:06 AM
โAug-25-2016 06:52 AM
โAug-25-2016 06:31 AM
โAug-25-2016 03:44 AM
nofoolin wrote:
Thought I would mention that turpentine which is a distillate of tree resin, usually pine, will likely be more effective for removing tree sap.
โAug-24-2016 06:36 PM
โAug-24-2016 04:20 PM
โAug-24-2016 04:09 PM
โAug-24-2016 03:56 PM
โAug-24-2016 02:30 PM
Bumpyroad wrote:
I hope gasoline doesn't harm the paint on my new Tacoma as I had to remove some tree sap and used that. I sort of "assume" that a gasoline vehicle shouldn't get skin rash from gasoline?? immediately washed it off however.
bumpy
โAug-24-2016 02:21 PM
Grit dog wrote:
In general, no, gasoline or even stronger solvents like lacquer thinner, brake or carb cleaner or acetone will not damage fully cured urethane clear coats.
I'll routinely use gas or one of the above to remove road tar, decal or trim glue/residue on paint, clear,and gel coat. I wouldn't use anything stronger like xylene or Mek.
N-Trouble wrote:
Gasoline??? Seriously??
Get ya some of these. Also Works great on trailer front cap
https://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Adobie%20pads
โAug-24-2016 02:10 PM
