mike326's avatar
mike326
GCVR?
Whilst GVWR seems somewhat violable - GCVR seems the wall. But how/where can I find the GCVR for my 2013 F150 Supercab 4WD SRW?
    It should be in your manual in the towing section.
  • For the most accurate specs for YOUR truck, ask the Ford dealer to run your VIN # and give you a print out with all your info. I have one from Dodge that I keep in the glove box.
  • If this helps . The below GCWR # was taken from here.
    see.....Trailer towing selector
    Bob
  • Ford should be able to tell you. But depending on who you listen too either can be a hard or volitle number
