Generator
6pac
How to gain access to spark plug on a Lance 881? Do I need to remove the generator just to change the plug?
Chevy 2006 2500HD 4 x 4 Duramax / Allison srw cc sb Fh air bags
Lance 2005 model 881 Max
Doriece & Ernest ( 6pac )
3 REPLIES 3
Kayteg1
My Generac is only 80lb, but still you can't just carry it out from compartment.
I lose the bolts, lower the camper with box or table under the generator, than I had to tilt generator to come off the railing and lift the camper with remote jacks.
AnEv942
Just curious..I thought option was a Generac, and if so is unit rotated in camper to make spark plug inaccessible?
Edit
Never mind- a little looking around appears probably an Onan.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
mkasner
Yes you'll need to drop the generator in order to get space to access the spark plug. The only thing accessible on these is the oil drain bolt and air filter.
We had to drop ours when it was first new, and it was a pain. Make sure you have a jack as it weighs alot!
