MainerBob
Sep 16, 2017Explorer
Glow Plugs
Last year my check engine light went on. Went to dealer and was told I had a bad glow plug but it was not necessary to fix it right away and when I did I should just do all 8 since if I had one bad o...
DiskDoctr wrote:Turtle n Peeps wrote:
Sorry but a burnt out glow plug does not swell like has been reported by a few on here.
That being said, I'm not an expert on Duramax, either.
At a MINIMUM, if pulling the cover to replace ONE glow plug, I would ABSOLUTELY replace all the ones on that side. Is it necessary to pay (DIY time or service labor) to remove the other valve cover to replace them...it depends. I probably would, since I usually DIY. If it wasn't too much in service labor, I'd have it done, too.
