Grit,
You win nothing!
For the rest of you, I guess grit too! Not sure why......
For 2021 the two GR options are 3.42 or 3.73 behind the 6.6 gasser. I don't recall looking this up las week if that motor has the 6 or 8 sp auto behind it.
If the 6sp, I'd be ok with the 3.73. would have to do some number crunching on the 3.42.
Need to look up gear ratios on 8sp to see if first is lower than the 4.10 1st gear in the 6sp. Is so, then a 3.42 could work on all ends, possibly get you some decent mpg's on freeway empty at 60-65 mph.
I do a lot of 0-50, a bit at 60. Almost none at 70!. So 3.73 generally speaking is best for me. Would prefer 4.10s even with the 6sp.
Marty
