I don't mean to rain on anyone's parade, and I certainly can't argue with success. For those who might not understand the limitations of these systems in their various interations (and names) they all basically operate the same way to my understanding.
There is a hole drilled in the center of the spindle which allows grease to be pumped to the rear of the inner bearing in front of the seal. The theory being that as you grease, the new grease will dispace the old grease toward the outer bearing and exit out the center of the spindle. To a large degree, these systems work. Usually.
If you are only pumping a few pumps and calling it good, you are not purging much, if any, grease out through the outer bearing unless the entire hub void is filled with grease. And if you are, any dirt or swarf from the inner bearing is pushed out through the outer bearing, so you may be contaminating one good bearing with the grease from the other. If you pump too hard, you can force grease out the seal behind the inner bearing onto your brake surfaces, which is a huge no-no. So, if you pump, pump gently and keep the wheel spinning if you can.
Many here, including myself, do not depend on the operation of these greasing systems and opt for the hand method because it's hard to screw up when you can see the bearing and make sure it's properly greased and the nut is tightened optimally. From my experience using this system before going to hand greasing, each axle can take up to a full tube to fill before satisfactorily purging enough old grease to make the system marginally beneficial. And then you end up with a hub FULL of grease with no air space for the grease to go into when heat and expansion work their magic.
After three years of using the Lippert Superlube system on our trailer, I couldn't stand not knowing anymore and changed out my Chinese OEM bearings for Timkens. I will say most of the bearings showed acceptable wear, but two in particular were on their way out. They were pitted and flaking and would have likely failed that season at some point.
My system now is, since PA mandates yearly inspections which require pulling two axles down at random to check brakes and bearings, when they put them back together and send me on my way, I automatically recheck and regrease those two hubs, and grease the other two without tearing down by using the Superlube system in the inner bearing (judiciously!) and a grease needle carefully on the outer bearing. I have them pull the alternate two every year. This way I have confidence that my components are optimally maintained with the same grease, and inspected without having to do a full tear down every year. Hope this helps.
