thedavidzoo
Aug 27, 2020Explorer II
Gut check on transfer switch for inverter - special case
A few years back we DIY installed our current lithium/solar system which is charged only through roof solar. We initially rewired a few 110V outlets dedicated to the inverter, including the microwave. We "never" plug into shore, do not have a generator, and do not charge the batteries via truck (disabled with switch at converter just in case). The generator compartment is prewired into an existing automatic transfer switch (shore or generator). Converter is standard dealer WFCO type.
We are now relooking all our outlets and USB charging ports to make them a little more logical for our uses. We would like to again rewire so that all 110V outlets run from the inverter. I hear that you do not want a loop where the inverter draws on the batteries, feeds back into the converter (using an automatic or manual transfer switch), and charges the batteries.
Now our system is a little different, I think. Our lithiums have individual cell BMS and an integrated battery control system "computer" (the brain) which regulates all battery in and out power among other things. We have no direct positive connection between converter and battery as would be the usual way. Any charging source (only solar now) comes through the C+ connection on the brain. All loads (to inverter, converter) go out through L+ on the brain. Therefore, I conclude that there is no way the converter can feed back into the batteries with the inverter powering the converter. Confused yet?
Plus, I think I can just wire the green manual transfer switch after the existing one so I can select the inverter or shore.
Also, our fridge is 110/12V compressor. I think I could just unplug its 110v cord and force it to run 12V when the inverter is on.
Wouldn't affect the furnace, only 12V.
Would only affect propane WH for initial spark? Wouldn't use electric WH on inverter anyway.
Wouldn't try to use AC air on inverter either, might have to rig thermostat switch against accidental bumps.
So many questions. My sketch, don't laugh. Thanks.
