JIMNLIN
Apr 28, 2015Explorer III
Mine on a 1984 Aljo was simple as all that was required was to pull the sealant from around the screw heads and remove them. I replaced it with one that was white and was advertised as unbreakable. Used the butyl tape under the flange and installed the screws. Scrapped off the excess butyl tape that squeezed out then used a roof sealant over the screw heads and lap joint just like OEM.
The white was much cooler than the smoke color OEM cover.
Now my neighbors skylight replacement was a different deal on his used trailer. Some RV newby had ran Eternabond around the skylight. I was 4 hours getting the 2 rows of Eternabond off and another 4-5 hours fixing the mess the neighbor made of the rubber roof on his attempt at removing the Eternabond.
44,030 PostsLatest Activity: Jan 21, 2025
