H2oSprt's avatar
H2oSprt
Half ton or Sequoia
I've been reading up a lot on weights and cargo capacity and I think I've found one that might work with a 2012 Sequoia, am I right? I realize a 2500 would be better but I'm looking to use a sequoia this time.
Dry Weight 3,609 lbs.
Gross Vehicle Wt Rating (GVWR) 5,865 lbs.
Axle Weight 3,344 lbs.
Cargo Carrying Capacity (CCC) 2,256 lbs.
Hitch Weight 265 lbs.
MEASUREMENTS
Length Feet 20.75
Overall Length 20 ft. 9 in.
Exterior Height 8 ft. 9 in.
Exterior Width 90 in.
Interior Height 6 ft. 4 in.
Wheels/Tires 14 in. tires on aluminum wheels
  • That TT looks like a nice match for the Sequioa and that's a nice vehicle. The only thing I'd remind you is if you ever want to go bigger the 1/2 ton platforms run out of room quickly. If there's ANY chance of wanting a bigger TT later you'll likely need to get a new TV as well. But, for what you are asking about, I say go for it.
  • The Sequoia is very nice. The Toyota 5.7 V8 is an excellent engine. But, they really can drink the fuel. A coworker has a 2012 Sequoia Platinum and a 2012 Suburban. The Suburban gets better fuel economy and has a LOT more room behind the third row seat. Any Big 3 half ton pickup with the largest V8 will get better fuel economy than the Sequoia, if that is even a consideration for you. But, on the other hand, if you just really have decided on a Sequoia, you will enjoy it.
  • 2010 Tundra 5.7 owner here, I get 15mpg average, mixed driving. 9-10mpg towing 7600lb 28' outback. I do tend to drive with a light foot which helps.
  • Ron3rd's avatar
    Ron3rd
    No problem pulling that trailer with the Sequoia IMO.
  • I think you'll be fine. Watch your payload in the Sequoia and the tongue limit. A half ton PU usually has a better payload than a half ton SUV.
  • That trailer would be an excellent choice for any 1/2 ton or the Sequoia. We have a '10 Sequoia Ltd 5.7l with third row seating and I wouldn't hesitate to tow the trailer you have listed with it...even in the mountains.
  • As already mentioned, the Sequoia will not have a problem towing that trailer. It will do just fine.
  • Get a good weight distributing hitch like the Equal-i-zer and you will never know that trailer is back there.
    You will get about 10 mpg towing with the Sequoia or anything else.
    A SUV is a very good tow vehicle in my opinion because you have a good dry & secure cargo area for valuables. I've always had more faith in the locks on a Toyota than the ones on the travel trailer.
