bguy wrote:
There's nothing like a bigger truck to mask a poor hitch set up.
The only time you will have a "poor hitch setup" with a larger truck is if the manufacturer of the trailer goofed or you goofed and put way to much heavy junk at the back of the trailer.
Most bumper pull trailers will have around 10% hitch weight and often they are heavier than 10%..
What I have noticed is a lot of folks tend to use WD to justify too big of a trailer on a undersized tow vehicle.. Don't you think THAT is a "mistake"?
I do.
It is the reason why I don't bother with 1/2 ton trucks. Sure, I could tow my 26ft 6K lb (7000 lb GVWR)trailer with a 1/2 ton but to do so I will need WD.. I do not need WD for my F250..
Could I tow my 2400 lb (10K GVWR) 18ft flat bed utility trailer with a 1/2 ton? Sure but would require a different WD hitch and setup and I would have to readjust every time I loaded up (run from empty to 8K+ loads all the time).. I do not need WD for my F250.
Why should I go to all that bother, hassle and cost when hopping up to F250 platform get rids of all that WD cost and hassle.
I would not recommend trying either of my trailers on a 1/2 ton platform without WD.. Especially my flatbed trailer, that one when loaded will put a 1/2 ton on to the ground when loaded up to GVWR..
I should have taken some pix a couple of yrs ago when I loaded some nice green Oak rounds that were nearly 4ft across.. A couple of those I had to noodle in half to get my front loader to pick them up.. Frontloader tops out at 980 lbs! Had 10 of those rounds plus tractor.. Would have killed a 1/2ton..
Ahh the freedom just by upsizing my vehicle platform is refreshing.
