mabynack
May 18, 2015Explorer II
AH64ID wrote:
You probably had some air in the line. Try turning the furnace off, running the stove for a couple min, and then turning the furnace back on. It may take a few cycles to work out any air and get ignition.
It is possible that the DSI for the furnace is bad, or that the thermocouple is bad. Do you hear any attempts at ignition or ignition?
Stand by the exhaust outside when it starts and see if it gets hot and then cold. Hot will be HOT so do not burn yourself.
X2
I usually have to turn the furnace off and on three or four times before the air gets out of the lines and furnace lights.
Check your gas to make sure it's on. If you have a switch to switch between tanks, make sure it's positioned properly.
Stand outside by the heater and listen for the igniter while someone turns the switch on.
44,056 PostsLatest Activity: Jan 19, 2025
