Nov-19-2017 02:37 PM
Nov-30-2017 03:53 AM
TomG2 wrote:7,000 lbs TT = 840 bls tongue weight + 175 lbs driver +150 lbs wife + 35 lbs firewood = Done!
. Do you seriously think that a tow vehicle with 1,200 pounds of factory payload is adequate to tow a 7k TT?
Nov-29-2017 07:09 PM
TomG2 wrote:I kinda do...troubledwaters wrote:
So your answer is what?
The answer is that saying that 1,200 or 2,000 is the right number is a matter of guessing and estimating without actual scale weights on which to base your decision. I will not go camping naked or leave my kids at home to meet some arbitrary number. Here is my question. Do you seriously think that a tow vehicle with 1,200 pounds of factory payload is adequate to tow a 7k TT?
Nov-29-2017 06:54 PM
LAJMINNIEPLUS wrote:Jerrybo66 wrote:
We have a Buick and a 1/2 ton truck that can be used for shopping but I usually take the F-350.Phoenix seems to have it's share of wrong way drivers so with the heavy power stroke in front and eight feet of bed in the back as a "texter" guard, I feel fairly safe. I can't park close to the store doors but a little extra walk is good.
Plus you need to have a nice heavy hitch hanging down to punch through the grill or bumper first.
Nov-29-2017 02:54 PM
Jerem0621 wrote:
But let me tell ya, that "Little bit rougher ride" over 80 miles Every...single...day... can turn into a kidney killing, back aching, machine. Of course, the new 2500's ride much better than my old F350 Dually.
Nov-29-2017 02:43 PM
Nov-29-2017 12:05 PM
TomG2 wrote:So your answer is what?wing_zealot wrote:It would be very easy to have less than 1,000 pounds of available payload after adding people and "stuff" to a vehicle that started out with a 1,800 pound rating. Topper, four people, generator, firewood, and a couple of toolboxes could put you well under 1,000 pounds of available payload. It is all about spending ten bucks at the scales for me to know for sure.
The discussion is, how much payload you need to haul a trailer with 1000 lbs of tongue weight. And the answer isn't 1800 lbs(as I have repeatedly shown you).
Nov-29-2017 10:49 AM
Nov-29-2017 10:10 AM
Nov-29-2017 09:27 AM
LAJMINNIEPLUS wrote:What my Ram and Trailer weighs has nothing to do with it.wing_zealot wrote:LAJMINNIEPLUS wrote:Your statement was that you need "At Least"1800 lbs of payload to pull a trailer with 1000 lbs of payload. Wrong!, all you need is enough for the tongue weight and driver. If you want cargo and passengers fine, add that in. You Don't add fluids, those are all ready included.wing_zealot wrote:LAJMINNIEPLUS wrote:You need to look what the term payload includes and doesn't include.
1200# isn't much in todays world and wouldn't be enough to haul most trailers in the 6-7k # range. You need at least 1700# to pull that much. My Sierra 1500 had a payload of over 1700# with a gross weight of 7200# and I was maxed out on gross hauling my 7500# Winnebago with just myself and wife as passengers and a few hundred pounds in the truck body. If your trailer has a tongue weight of 1000# and your truck needs at least 1800# payload in order to fit passengers/fluids/etc...
1000 lbs of tongue weight and 200 lbs driver, what's the other 600 lbs for?
Going camping alone with no gear in the truck? Usually there is at least 1 -4 additional passengers and other gear in the truck bed. It all adds up quickly as payload. And the payload adds to the gross truck weight along with gasoline and other fluids.
And you certainly don't need 1800 lbs of payload to haul a 6000 lbs trailer.
I can haul my 7600 lbs trailer with my 1500 lbs payload Ram and have enough payload to take my wife, toolbox, and a 100 lbs of firewood and have over a 100 lbs of payload left over.
My trailer weighed over 8000# when I took a trip out west this past Fall and I could certainly "haul" it. A lot of it boils down to the quality of ride when you approach your load limit. When loaded for local camping, I had at least 500# of payload reserve and was quite happy with the ride. But, when loaded for a long trip, my truck was maxed at exactly 7600# and the ride on some less than smooth concrete highways and bridges was not quite pleasant.
Have you put your Ram and trailer on the scales to see what it actually weighs?
Nov-29-2017 09:17 AM
TomG2 wrote:
How many of these weights are actual scSale weights or are they "estimates"? I learned a lot when I started weighing my rigs about fifteen years ago. A fiberglass bed cover, generator, girlfriend, tool box, and a few other items left me with very little (600 pounds) of payload on my mighty F-150 back then.
Nov-29-2017 09:10 AM
Nov-29-2017 06:05 AM
TomG2 wrote:
How many of these weights are actual scale weights or are they "estimates"? I learned a lot when I started weighing my rigs about fifteen years ago. A fiberglass bed cover, generator, girlfriend, tool box, and a few other items left me with very little (600 pounds) of payload on my mighty F-150 back then.
Nov-29-2017 05:01 AM
Nov-29-2017 03:59 AM
Nov-28-2017 04:57 PM
