Travelmankid wrote:
Manfred wrote:
Hi all,
I was wondering if it is OK to lubricate the rail/gear on the Heco lift system. My 2005 Northstar 850SC, cranks up OK but I'm thinking everything would glide smoother with some lubricant. Is it advisable to lubercate these components and if so, what would you use, silicone? Thanks
it is generally advisable to lubricate the mechanical components of camper lift systems, including those on the Northstar 850SC, to ensure they operate smoothly and to reduce wear.
When I initially read your post, I read it as not advisable to lube, looks like it would be OK to do so. I check out the lube that was recommended and give it a try. Thanks .:)
