Manfred's avatar
Manfred
Heco lift system
Hi all,
I was wondering if it is OK to lubricate the rail/gear on the Heco lift system. My 2005 Northstar 850SC, cranks up OK but I'm thinking everything would glide smoother with some lubricant. Is it advisable to lubercate these components and if so, what would you use, silicone? Thanks
  • Travelmankid wrote:
    Manfred wrote:
    Hi all,
    it is generally advisable to lubricate the mechanical components of camper lift systems, including those on the Northstar 850SC, to ensure they operate smoothly and to reduce wear.
    When I initially read your post, I read it as not advisable to lube, looks like it would be OK to do so. I check out the lube that was recommended and give it a try. Thanks .:)
  • Thanks for the thoughts and lubricant recommendation. Awhile ago I read a post on another forum where a member disassembled his HECO lift system, cleaned and lubed the track and gear as well as reloaded the torsion spring - was thinking maybe some lube would keep things operating smoothly, but not so sure now. I was thinking of doing the disassembly in the future as the top progressively gets harder to crank up. I'm a little intimidated about disassembling the lift as I would need to support the top during the process. Anybody know of a RV outfit in the greater Portland, OR area that works on the HECO systems? I know they are no longer installed but you can still get parts. Thanks
  • Manfred wrote:
    Hi all,
