DennisNYS's avatar
DennisNYS
Hellwig Sway Bar on Ram ...
I would like to put a sway bar on the rear of my TV,
04.5 Ram SRW 3500.
Would like to use Hellwigs 'Big Wig'.
Small concern .... will the sway bar interfere with lowering,
the spare tire ?
  • DennisNYS wrote:
    FWIW.
    Spoke with a rep at Hellwig.
    The Big Wig sway bar will fit my truck without interference.
    I assumed it would be fine but you got the right answer.
  • FWIW.
    04.5 Ram SRW 3500.
    the spare tire ?
    You can ask here but the only answer you should trust is from Hellwig!
