Empire402's avatar
Empire402
Help identifying a camper jack
I have an old camper jack that is leaking around the plunger, I was hoping someone could help me identify a brand/model so I could get a seal kit. There is no labeling left on the unit so I don't know how to tell what it is.
Thanks in advance for your help.
  • It's a Shur Lift, Hijackers and Reico-Titans have their valve and piston at a 90 degree angle to the cylinder. Shurlifts come in from the bottom.
    Unfortunately, Shurlift is long since out of business, so the rebuild option is to buy a reico titan or hijacker jack set as a replacement if you want to stick with Hydraulics.
  • Thanks for all the help, I have contacted Glenn at hijackercamperjacks.com and he says that it a Shurlift jack and he should be able to help me out with a seal kit so I should be good to go.
  • That is a high jacker. Had them on my Coachmen ranger.
    https://hijackercamperjacks.com/
