StirCrazy
Jan 20, 2023Moderator
is the reason you cant get the batteries charged back up because of limited hours you can run your genny? if so think about adding solar to the mix, of course get the batteries tested and see what their capacity is. if they are ones that come with the camper get better ones. eveything else is good advice check the size of the converter and if its working right and so on, but adding solar will give you that chrging capability all day long, not just during hours when your alowed to make noise.
