Russg3's avatar
Russg3
Help! need bunk latches
I have a 2000 9ft Trail lite Hybrid in Good condition except for the screw down latches that hold the bunks in a closed position. Some are rusted so bad they no longer work and I can't seem to locate replacement parts. Any ideas?
    I just replaced mine a couple of weeks ago, you can order the better latches off ebay or I got mine from here - https://www.horsetraileraccessorystore.com/
    Pretty easy mod to do and way better than the screw-in locks which were poorly designed.
  • links to latches from www.tweetys.com
    http://tweetys.com/search.aspx?find=latches&page=27
    http://tweetys.com/search.aspx?find=latches&page=26
    I used to have a Forest River Hybrid with the same problem.
  • Pull up this link: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21386776.cfm
    It is for a Rockwood Roo, but the latches should be the same.
    Link for Trail lite: http://arveeclub.com/forum/index.php?topic=69572.0;wap2
