BamarickandlisaExplorerMay 19, 2014Help on a 30 amp RV plugThe ground and neutral are together in the box that I'm hooking up my 30 amp rv plug. Do I need to get a new box that has a separate ground or is it a way to hook the RV plug up? 120v with 30 amp br...Show More
GrandpaKipExplorer IIMay 19, 2014In your house breaker box, the ground and neutral should be bonded. Not in the RV.
Related Content30 Amp Plug50 amp plug30 Amp Plug Diagram50 amp plugHaving 30 amp plug installed at home
